.lcf file
.lcf file
Amihay
I am trying to write lcf file for a new project.
does anyone can direct me to a link or user manual that list all available commands
and the format of it?
Thanks in advance
Amihay
stanish
Hi Amihay,
Linker Command File (.lcf) syntax is a bit different for different CodeWarriors. (CW for CF, CW for DSCs...)
I'd suggest you to see "<CodeWarrior root directory>\Help\pdf\*Build Tools*.pdf", "LCF Syntax" section.
Stanish
