just run with single step
1,526件の閲覧回数
ustcsnaker
Hi,everyone!
I'm using the MC9S12XEP100.
When I debug the codes,  some parts can only be dedugged with single steps. And I set some breakpoints. The codes don't run to the breakpoint. I want the reason!
Thanks for your help!
2 返答(返信)
1,364件の閲覧回数
kef
Specialist I
Make sure you have checked in debugger
HC12MultilinkCyclonePro->Setup...->Debug options->Disable maskable ISR's when stepping.
1,364件の閲覧回数
ustcsnaker
Kef, I'm sorry for replying you so late. It's all because of errors in codes. I've solved the problem. Thank you very much.
ustcsnaker
