iMX21ADS
iMX21ADS
support
Hi all
I download the iMX21ADS start to install (I copy the img disk to home directory) and after long time I get failed The error log is attached R.G
Voxan
Hi there,
This BSP is based on LTIB, which provide a lightweight cmd line interface to PERL scripts. It allows you to perform Builds, Deployments, Packages Management, Captures (patches...)
to know more about LTIB: http://savannah.nongnu.org/projects/ltib
Packages are publicly available (GPP) at http://www.bitshrine.org   Ltib acesses GPP over the internet to retrieve all needed components for a BSP.
All main Linux distributions are supported, RedHat, FedoraCore, Debian, Suse
Installation process:
- mount the BSP image:
$ sh <mount point>/install
- run the ltib install script as a regular user (not root):
$ cd <install path>/ltib
$ ./ltib
NOTE: the first time LTIB will build and install the host side packages, which will take quite a long time...
Hope this helps...
