flash memory issue
flash memory issue
4,542件の閲覧回数
harry
I am using a Dflash bean . the chip is a56f8367 .i am getting a flash error.
whem i try and write to flash any ideas????
タグ(1)
2,244件の閲覧回数
Chris11
Did you check what error message you're getting back?
Are you using a safe write?
Are you writing to a reasonable flash data memory address?
Maybe you should post your code if you haven't solved it already.
