eclox install failure
1,842件の閲覧回数
barbercolman
I am trying to install eclox in CW10.1 and I get a install has encountered a problem.
The relavent error appears to be "no repository found containing:smileysurprised:sgi.bundle, freescale.arm.debugginer.cbt,10.1.1"
There is a list of this type of error.
Any idea on how to resolve?
2 返答(返信)
1,455件の閲覧回数
Mick92
I'm using Eclox in CW 10.1 and 10.2 without any issue. You just need to add the following address in preferences ("Available Software Sites"):
http://download.gna.org/eclox/update
Then install it with Help/Install New Software...
1,455件の閲覧回数
viluvilu
I have the same issue with Codewarrior 10.2
Install procedure fails with this error:
Unable to connect to repository http://download.gna.org/eclox/update/content.xml
Connection refused: connect
I have also tried to install eclox ver 0.8.0 form package zip downloaded from http://home.gna.org/eclox/#packages
but install fails.
Some ideas ?
