eclox install failure
barbercolman
I am trying to install eclox in CW10.1 and I get a install has encountered a problem.
The relavent error appears to be "no repository found containing:smileysurprised:sgi.bundle, freescale.arm.debugginer.cbt,10.1.1"
There is a list of this type of error.
Any idea on how to resolve?
Mick92
I'm using Eclox in CW 10.1 and 10.2 without any issue. You just need to add the following address in preferences ("Available Software Sites"):
http://download.gna.org/eclox/update
Then install it with Help/Install New Software...
viluvilu
I have the same issue with Codewarrior 10.2
Install procedure fails with this error:
Unable to connect to repository http://download.gna.org/eclox/update/content.xml
Connection refused: connect
I have also tried to install eclox ver 0.8.0 form package zip downloaded from http://home.gna.org/eclox/#packages
but install fails.
Some ideas ?
