configure I/O
configure I/O
4,423 次查看
dspfusm
HI!!!!
I need to konw how i configure a pin to GPIO to  in or out.
thanks
Message Edited by Alban on 2007-03-30 12:36 PM
4 回复数
1,699 次查看
Alban
Senior Contributor II
Your subject does not match requirements and you don't give any details.
This is not possible to help you when you give nothing.
Please read the rules if you don't want your messages to be deleted.
Alban.
1,699 次查看
peg
Senior Contributor IV
Seeing how we are talking about the general case here, the answer is:
By setting or clearing the appropriate bit in the appropriate direction control register.
1,699 次查看
Alban
Hi David,
If you had not answer this post, I would have deleted it.
Alban.
1,699 次查看
peg
It was only meant as a satirically useless answer to point out the useless nature of the question.
