change processor in imported project
2,388件の閲覧回数
bc2
I imported the acim vc shut project into cw 10.2 and it comiles with out issue. I would like to change from the MCF8013 to the MCF56f8257 and have no idea how to change processors on this old a system. Do I even change processor or do I create a new barebone project?
2,301件の閲覧回数
J2MEJediMaster
Specialist I
Best way to continue forward is to create a new bare-board project in CW v10.x. The project importer tries to do a good job, but as you've probably found out, it isn't perfect, and sometimes you have to spend some time tweaking things to get the imported project to build properly under CW v10. If you're going to do that, you might as well make a clean break and spend the effort on a project that doesn't have any legacy baggage to deal with.
---Tom
