View stderr when using assert
1,589 次查看
DSabol
I am new to using CodeWarrior and cannot figure out how to have stderr display when assert trips so I can see the file, line, etc.  I'm using CodeWarrior IDE version 5.6.1.1658
Thanks for the help
Dave
1,471 次查看
CrasyCat
Specialist III
Hello
- Which CPU are you targeting (HC08, HC12, Coldfire, ..)
- Which version of CodeWarrior are you using?
    To retrieve that info:
    - Start CodeWarrior
   - Select Help -> About Freescale CodeWarrior
   - Click on "Install Products"
   - CodeWarrior version used is displayed on top in the Installed Products dialog.
CrasyCat
1,471 次查看
CrasyCat
Specialist III
This discussion was moved to a better location.
