Syntax coloring for numbers??
已解决
跳至解决方案
2,434 次查看
r1_sgi
I’m using CodeWarrior 7.1 on Mac OS X.
I’d like to use syntax coloring for numbers, like in Apple’s Xcode IDE.
I tried the « custom keywords » preference pane by adding all the numbers from 1 to 9 but that doesn’t work (the numbers still draw black).
Any suggestions or do I have to write my own COM plugin ?
标签 (1)
1 解答
1,650 次查看
CrasyCat
Specialist III
Hello
  Freescale CodeWarrior no longer supports desktop programming for Mac or Windows.
  So you may not find an answer to your question here.
  As far as I know CodeWarrior IDE does not support specific coloring for numbers anyway.
CrasyCat
在原帖中查看解决方案
2 回复数
1,650 次查看
r1_sgi
anyone??
1,651 次查看
CrasyCat
Specialist III
Hello
CrasyCat
