Standard vs Professional? What's the difference?
3,560 次查看
GaryOlmstead
Senior Contributor I
Hi --
I have a program that is too large for the eval version, but I am stumped between the Standard and Professional versions.  Both descriptions say Unlimited C, Unlimited assembly, Processor Expert with basic and advanced beans, and data visualization.  No other description, but the Professional is twice as much.  So, what would I get?
标记 (1)
2,142 次查看
GaryOlmstead
OK, thanks.  That document wasn't all that helpful. But it turned out that the free version did compile it after all, so I can put off a decision for awhile yet.
As for processor support, I have nine different versions of CW on this computer, and it looks like I will be adding another one pretty soon.
Thanks for your help.
Gary Olmstead
Toucan Technology
Ventura CA
2,142 次查看
admond
Professional supports more other chips such as mcu except DSC. I recommand you the standard one. if you just use CW for DSC, it is enough. any more advice is appreciated. this is my view.
2,142 次查看
J2MEJediMaster
Specialist I
The tool capability between the Standard and the Pro versions are identical. As armond mentioned, the Pro version supports more processors, and maybe provides some more Beans, but do not hold me to that latter. I've attached a datasheet that you can study.
---Tom
2,143 次查看
GaryOlmstead
Gary Olmstead
Toucan Technology
Ventura CA
