Stack Consumption for HC12 using Code Warrior v5.2
MerlinBDX
I am trying to compute the stack consumption on a MC9S12XDP512 microcontroller.
According to Code Warrior's v5.2 Build_Tools_Utilities.pdf in the Stack Consumption Computation section: "Older versions of the compiler may not issue the information. Also, this feature is currently only supported for HC(S)08 derivatives."
I want to know how to compute the stack consumption for my application. I saw in answer to another question that CW v5.1 did support the feature, therefore v5.2 should as well, I presume.
Thanks in advance.
Tags (2)
Hello @MerlinBDX
Please add below code on .prm file:
STACK_CONSUMPTION
ROOT main
END
END
Alice
Hello @MerlinBDX
Please enable Stack Consumption as follows:
Alice
MerlinBDX
Hello, Alice, thank you for your response.
I have activated the options you mentioned and when compiling I get this message:
Following the PDF of the Build Utilities, I went into the PRM file and added these lines at the end:
But now I am getting this error:
On this line:
Can you please advice on how to solve this?
Hello @MerlinBDX
STACK_CONSUMPTION
ROOT main
END
END
Alice
MerlinBDX
Thank you, this worked
