Problems of Space Cost when Using CW10.1
1,148 次查看
ersh
Now I'm using CW10.1 to develop projects on K60.And I find a strange problem.When using CW10.1, my space of disk C  becomes less and less, and it can cost nearly 5G to 6G , I find a file"codewarrior.log" in my folder /user/.codewarrior/ and it is 5-8G, so I delete it and nothing wrong with CW10.1.Can somebody help me to avoid this very very big file come up? My disk C  is just has 15G left...
1,036 次查看
J2MEJediMaster
Specialist I
First, check that logging is turned off in the project's Debug Configuration. (Run > Debug Configurations >  {your project name} > Edit.)
Second, check out this blog article on clearing out some of the data tha the IDE leaves around in the workspace.
---Tom
