Prefix Text in CW6.3
2,274 次查看
ignisuti
I have a project_defs.h file that I want included into every file of my project. Can I use the Prefix Text option for this?
I tried adding #include "project_defs.h" to the Prefix Text field, but got tons of "preprocessor syntax error" messages.
5 回复数
1,828 次查看
CrasyCat
Specialist III
Hello
  Which CPU are you targeting (HC08, Coldfire V1, ..)
CrasyCat
1,828 次查看
ignisuti
It's Coldfire V1.
MCF51CN128
1,828 次查看
CrasyCat
Specialist III
Hello
Inside of the Prefix Text edit box you need to specify
    #include "my_include.h"
If your prefix file name is my_include.h.
Then next question is where is that file located?
Is the path to this include file specified in the list of user Paths inside of the Access Paths list box?
CrasyCat
1,828 次查看
ignisuti
Yes, I've placed this file in my Sources folder which is the Access Paths.
Well, my #include "project_defs.h" command should work then...?
1,828 次查看
ignisuti
Hold on...
I'm almost too embarrassed to say this, but for the sake of honesty... I forgot the qoutation marks.  :robotsurprised:
It's working fine now.  Sorry to waste your time on this one.
