How to call assembly function in C program
5,002件の閲覧回数
snehita
Need help for how to call assembly function in C program. i know we can call asemblly function by asm instruction. but i want other option.
Please help me.
Thanks in advance
Snehita
タグ(1)
1,157件の閲覧回数
trytohelp
The project wizard contains an example like this.
In the IDE select File ¦ New. Select DSP56800x_EABI Stationnery.
Select simulators for instance. There is an example named Simple_Asm_and_C.
This is a mixing project.
An assembler function is called in the main c routine.
Hope this will help you.
Pascal
