How do I obtain CodeWarrior 5.6?
3,906 次查看
jerry_rubinow
One of our sites is using CodeWarrior 5.6 to compile ColdFire 5235 firmware.  We want to setup an automated build at another site.  How would we go about purchasing and downloading this obsolete version of CodeWarrior?  I tried downloading an eval copy of CodeWarrior 7.2, but that is 32bit OS only, and we are running 64bit OSes (Windows 10).  Thanks for any help.
9 回复数
3,586 次查看
ZhangJennie
CodeWarrior for Coldfire v7.2 can't support 64bit win7. Neither any other older CodeWarrior versions.
Only CW eclipse can support ColdFire on 64bit platform.
Please download it here
https://www.nxp.com/support/developer-resources/software-development-tools/codewarrior-development-t...
Jennie Zhang
3,586 次查看
jerry_rubinow
There is too much risk in our development schedule to upgrade to a newer compiler and retest everything, so using the Eclipse-based platform is not an option.
It is simply not true that 64bit OS is unsupported in 5.6.  Yes, the 7.2 installer will refuse to install on a 64-bit OS.  However, when I did a test with the installer for 5.6 that our other site is using, it had no problem installing under Windows 10 64bit and compiling the source code.
Obviously we don't want to use the compiler without a license, and the install I did try will stop working after 30 days anyway.  So let me ask my original question again: is it possible to purchase a license for 5.6?
Thank you,
Jerry
3,586 次查看
ZhangJennie
Hi Jerry,
There is no CW5.6 license available for download, the oldest license available is CW6.0. Normally CW license is backwards compatible, thus CW6.0 license also support CW5.6.
But the key problem is that the old version driver can't support new windows system.
Can your CW5.6 connect coldfire board on 64bit win7? Have you test it already?
Jennie Zhang
3,586 次查看
jerry_rubinow
Hi Jennie,
Thanks for the info.  How would I go about getting a CW6.0 license?  We are not using the coldfire connect support of the IDE in 5.6.  We are just using it to compile firmware, not to debug, emulate or run on an actual board.  It is not ideal and in the future we will upgrade.  But for now, we need an automated build that can perform the compilation using a licensed installation of CW 5.6.
Jerry
3,585 次查看
ZhangJennie
Hi Jerry
I just made a video to show how to download CW6.0 license from my side. see attached
Jennie Zhang
3,585 次查看
jerry_rubinow
Hi Jennie,
I don't think you attached the correct video.  The one you attached shows importing an SDK into an existing project.  I want to know where I need to go on the web site in order to purchase a license for version 6.0.
Jerry
3,585 次查看
ZhangJennie
Hi Jerry,.
Sorry, please see attached.
At the end of this video, click on "License Keys" to download the license.
Jennie Zhang
3,585 次查看
jerry_rubinow
Hi Jennie,
When I go to that page, I only see the products for which I downloaded an evaluation copy (see attached screen shot).  I do not see the "NXP Software" link.
Jerry
3,585 次查看
ZhangJennie
Hi Jerry
Normal This is because you never purchase a license. Thus you can only download evaluation license.
click on "previous" button to see if there is CW6.x for Coldfire evaluation license, if not, try CW7.2 evaluation license.
You can create a private case to NXP support team to request an evaluation license for your version of CW.
But the perpetual license is not free, we need purchase.
Jennie Zhang
