How To Print a byte array on Debugger Shell Window by converting ASCII and using TLC commands?
gokhangocmen94
Hello all,
I have a byte array variable. I can print it on Debugger Shell Window by using "display byte_array_name" TLC command. However, I want to print it on Debugger Shell Window by using TLC commands as ASCII. How can i do this?
Tags (2)
ZhangJennie
Hi Gokhan Gocmen
What's your chip part number?
Best Regards
Jun Zhang
