【HELP】How to trace a variable in a function in debug Mode
3,755 次查看
commandoccz
In CW 4.6  ,I want to trace a variable in a function. In the Data window ,I input the variable name when I press the "Add Expression..." ,But in the Data window it says"temp  running (unknown identifier)"
How can I know the value of the variable. Is there any HandBook about CW debug skills.
thanks
标签 (1)
3 回复数
2,089 次查看
commandoccz
3Q~~~~~HEHE
2,089 次查看
ubhims
The Targeting Manual for your CodeWarrior should have a section/chapter on Debugging.
-Mandeep
2,089 次查看
CrasyCat
Specialist III
Hello
There is a FAQ on that topic.
    Go to www.freescale.com and search for FAQ-27481
Please note that if the variable is a local variable the variable value might not be saved on the stack for optimization purpose.
In that case the variable value will not be available in the Data Window.
CrasyCat
