Flashing a S-Record file using USB TAP debugger (ONCE)
2,071件の閲覧回数
Kanthi
Can we flash a S-Record file on to the controller board using a USB TAP Debugger?
タグ(1)
1,016件の閲覧回数
J2MEJediMaster
Specialist I
Check out the Flash Programmer users guide.doc file located in {CodeWarrior Installation}\56800x Support\56800E flash programmer\docs. It mentions that you can use both ELF and S-records with the 56800E Flash Programmer application.
