Filling unused Flash locations
conte
How can I fill the unused flash locations with a certain value ?
Thank you.
trytohelp
I can propose you to use the Fill Memory feature:
You can fill the memory with a value (0x11 for instance) before to load the application.
What is the process ?
- on the ide click on debug | Connect via the debug menu,
- the debugger will be launched,
- go to Debug | DSP56800E | Fill Memory
For details, please refer to the Targeting_56800E.pdf manual.
Pascal
