Could CW8.3 work on Win10?
已解决
跳至解决方案
1,697 次查看
daweiyou
Before, some engineers could install CW8.3 on Win7 64bit, which work fine following AN4338.
But they feedback which couldn't work on Win10, any suggestion? thanks
1 解答
1,411 次查看
ZhangJennie
Hi David.
CW8.3 can't be well installed and used on 64bit win10.
officially we don't have wrokaround for it.
As a suggestion, you can try how it works with admin in compatible mode in win 10
Jennie Zhang
在原帖中查看解决方案
1 回复
1,412 次查看
ZhangJennie
Hi David.
Jennie Zhang
