Codewarrior IDE integration with QVCS version control software
2,597件の閲覧回数
mikeiz
Can I integrate QVCS Pro revision control software with Codewarrior? How do I do it? The version control options under VCS Settings have the Methods: mwCVS, SourceSafe and MW ClearCase.Is one of these compatible with QVCS?
Mike
1,149件の閲覧回数
CrasyCat
Specialist III
Hello
I do not know QVCS at all, but I would guess that none of the supported VCS software are compatible to this software.
So it is not possible to integrate that software inside of CodeWarrior.
Usually customer dealing with VCS software are building from make file (using make utility provided by VCS software) and are using CodeWarrior command line build tools.
CrasyCat
