CodeWarrior Command Converter Server
lucacarta
How can I download the installation files for CodeWarrior Command Converter Server (for 56F83xx)?
I need to install only 56800E Flash Programmer without install all CodeWarrior (on testing machine) and I need to install only CodeWarrior Command Converter Server.
Thanks a lot
L
trytohelp
This tool is available.
However this is not still available on our web site.
I can provide you this tool but I need to put it on a ftp server.
To do this you need to log your request to our Freescale CRM system.
Please use Freescale on line support web page.
  - Go to following URL: http://www.freescale.com/TechSupport
  - Click on Submit a Service Request. You will come to a login page.
  - You can submit your request through the web from there.
Pascal
