CodeWarrior 5.1 On Windows Vista
sstew998
Has anyone installed CW5.1 on Windows Vista?
I am currently running the installation which terminates with an error:  "Unable to find file c:\windows\inf\windrvr6.ini:
The file does infact exist in the above directory, however once this error is generated and you click <ok> to the messge box, the installation terminates and rolls back.
Any thoughts?
sstew998
UcTechnoGeek
Fresh Out Contributor
CW 5.1 does not work with Vista.
You need to move to 6.1 or better.
