Classic - Is it possible (How) to use HCS12 on Eclipse?
Classic - How to use HCS12 on Eclipse?
-build and debug a CodeWarrior project-
            Valid for some Classic versions - CW for MCU V6.x, CW for HC12 V5.1, etc ...
Configuration used:
                Software
Native installation Win 7 Enterprise 64 bit
                                CodeWarrior HC12 v5.1
                                CodeWarrior for MCU V10.6.4 (Updates 5&6)
                Hardware
                                S12XDT512
                                Multilink Universal rev B
Introduction
Since 2010 we started to move our development tool chains from Classic IDE to Eclipse.
However we continue to use classic tools for some products as CW for HC12 V5.x for HCs12 devices.
The advantage of HC12 is that all features are used in command line in the IDE.
So we can use another IDE than CodeWarrior IDE as Eclipse for instance.
This doc will show you how to:
  • - Create a new project using CW HC12 build tools chain,
  • - Define the external debugger to debug the HC12 application.
Attached you will find:
  • - a zip file including the projects. Recommend to unzip it to c:\temp,
  • - 2 videos explaining Build and Debug processes.
More references/information can be found at:
            https://community.freescale.com/message/364157#364157
http://mcuoneclipse.com/2012/02/13/make-my-make-with-eclipse-and-mcu10/
NOTE:
For Classic versions using integrated debugger, only the build operation can be done under Eclipse.
When the debugger is not available as standalone version there is no way to define an External Tools in Eclipse.
Phase 1: Create a Project under Eclipse based on a HC12 project
  1. 1-      Create a project for the device you need under HC12 v5.1.
  1. 2-      Launch Eclipse and create a new empty project
                File ¦ New ¦ Other …
Enable Show All Wizards and select the C Project (which is otherwise hidden), pressing Next.
Click OK
Specify the project name, select an Empty Project under Makefile project with — Other Toolchain — and press Finish:
Now I have an empty project
Using Project ¦ Properties specify my Build Command:
                ${system:ECLIPSE_HOME}/../gnu/bin/mingw32-make -j6
  1. 3-      Copy all HC12 V5.1 Sources and config files to Eclipse project
  1. 4-      Create a makefile with the menu File ¦ New ¦ Other... ¦ General ¦ File
Phase 2: Build the project using HC12 build tools chain with makefile
  1. 1-      Generate the Commandlines used by HC12 v5.1 to build the project.
By this way you will have the options and other paths used for compiler and linker to build the project.
We can use these information to create the makefile.
  1. 2-      Create the makefile with the menu menu File ¦ New ¦ Other... ¦ General ¦ File
An empty makefile is created.
You need to create your makefile according to your project.
For more details we recommend to refer to the link:
This is the makefile created for this example.
The makefile created contains 2 operations:
                                all -> build the project and generate Srecord files
                                clean -> remove all generated files
  1. 3-      Create 2 make targets
for all and clean operations with the "Make Target" under Window ¦ show View
Now I can build the project using HC12 v5.1 tools (compiler/Linker) under Eclipse project
Phase 3: Add External debugger to debug hc12 application
HC12 V5.1 is using an external debugger named Hiwave.
This tool is using a config file named .ini.
To use HiWave under Eclipse project, we need to define it as external Debugger.
By the Run menu click on External Tools ¦ External Tools Configuration…
Run will launch the Debugger and the project.ini file will be generated in the \Bin folder
                You can edit the ini file and use the info provided in the .ini file of HC12 V5.1 project
To use these settings, add the Arguments:
                project.abs -w -Target=icd12 -Prod=project.ini
Now the debugger is launched and application loaded on board with Multilink Interface.
标签 (1)
附件
评论
I try to follow the tutorial, but the attached files are not available.
Could you please send me the makefile?
Thanks!
%3CLINGO-SUB%20id%3D%22lingo-sub-1128942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%BB%8F%E5%85%B8%20-%20%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%EF%BC%88%E5%A6%82%E4%BD%95%EF%BC%89%E5%9C%A8%20Eclipse%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20HCS12%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2020.0pt%3B%22%3E%E7%BB%8F%E5%85%B8-%E5%A6%82%E4%BD%95%E5%9C%A8%20Eclipse%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20HCS12%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2016.0pt%3B%22%3E-%E6%9E%84%E5%BB%BA%E5%B9%B6%E8%B0%83%E8%AF%95CodeWarrior%E9%A1%B9%E7%9B%AE-%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CEM%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E9%80%82%E7%94%A8%E4%BA%8E%E6%9F%90%E4%BA%9B%E7%BB%8F%E5%85%B8%E7%89%88%E6%9C%AC%20-%20MCU%20V6.x%20%E7%9A%84%20CW%E3%80%81HC12%20V5.1%20%E7%9A%84%20CW%20%E7%AD%89...%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%209.0pt%3B%22%3E%E4%BD%BF%E7%94%A8%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%209.0pt%3B%22%3E%E8%BD%AF%E4%BB%B6%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.5in%3B%20text-indent%3A%200.5in%3B%22%3E%3CEM%20style%3D%22font-size%3A%209.0pt%3B%22%3E%E6%9C%AC%E6%9C%BA%E5%AE%89%E8%A3%85%20Win%207%20Enterprise%2064%20%E4%BD%8D%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%209.0pt%3B%22%3ECodeWarrior%20HC12%20v5.1%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%209.0pt%3B%22%3ECodeWarrior%20for%20MCU%20V10.6.4%EF%BC%88%E6%9B%B4%E6%96%B0%205%20%E5%92%8C%206%EF%BC%89%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%209.0pt%3B%22%3E%E7%A1%AC%E4%BB%B6%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%209.0pt%3B%22%3ES12XDT512%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%209.0pt%3B%22%3EMultilink%20Universal%20rev%20B%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CEM%3E%20%3C%2FEM%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E7%AE%80%E4%BB%8B%3C%2FP%3E%3CP%3E%E8%87%AA%202010%20%E5%B9%B4%E8%B5%B7%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BC%80%E5%A7%8B%E5%B0%86%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E9%93%BE%E4%BB%8E%20Classic%20IDE%20%E8%BD%AC%E7%A7%BB%E5%88%B0%20Eclipse%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E4%BB%AC%E7%BB%A7%E7%BB%AD%E5%AF%B9%E6%9F%90%E4%BA%9B%E4%BA%A7%E5%93%81%E4%BD%BF%E7%94%A8%E7%BB%8F%E5%85%B8%E5%B7%A5%E5%85%B7%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%A8%E4%BA%8E%20HCs12%20%E8%AE%BE%E5%A4%87%E7%9A%84%20HC12%20V5.x%20%E7%9A%84%20CW%E3%80%82%3C%2FP%3E%3CP%3EHC12%20%E7%9A%84%E4%BC%98%E7%82%B9%E6%98%AF%E6%89%80%E6%9C%89%E5%8A%9F%E8%83%BD%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%9C%A8%20IDE%20%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20CodeWarrior%20IDE%20%E4%BB%A5%E5%A4%96%E7%9A%84%E5%85%B6%E4%BB%96%20IDE%EF%BC%8C%E4%BE%8B%E5%A6%82%20Eclipse%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E5%B0%86%E5%90%91%E6%82%A8%E5%B1%95%E7%A4%BA%E5%A6%82%E4%BD%95%EF%BC%9A%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E-%20%E4%BD%BF%E7%94%A8%20CW%20HC12%20%E6%9E%84%E5%BB%BA%E5%B7%A5%E5%85%B7%E9%93%BE%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%EF%BC%8C%3C%2FLI%3E%3CLI%3E-%20%E5%AE%9A%E4%B9%89%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%E6%9D%A5%E8%B0%83%E8%AF%95%20HC12%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E9%99%84%E4%BB%B6%E4%B8%AD%E6%82%A8%E5%B0%86%E5%8F%91%E7%8E%B0%EF%BC%9A%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E-%20%E5%8C%85%E5%90%AB%E9%A1%B9%E7%9B%AE%E7%9A%84%20zip%20%E6%96%87%E4%BB%B6%E3%80%82%E5%BB%BA%E8%AE%AE%E8%A7%A3%E5%8E%8B%E5%88%B0%20c%3A%5Ctemp%EF%BC%8C%3C%2FLI%3E%3CLI%3E-%202%20%E4%B8%AA%E8%A7%86%E9%A2%91%E8%A7%A3%E9%87%8A%E6%9E%84%E5%BB%BA%E5%92%8C%E8%B0%83%E8%AF%95%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%9B%B4%E5%A4%9A%E5%8F%82%E8%80%83%2F%E4%BF%A1%E6%81%AF%E5%8F%AF%E5%8F%82%E8%A7%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%222020%22%20data-containertype%3D%2214%22%20data-objectid%3D%22315978%22%20data-objecttype%3D%221%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F315978%23364157%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F364157%23364157%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200.5in%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fmcuoneclipse.com%252F2012%252F02%252F13%252Fmake-my-make-with-eclipse-and-mcu10%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fmcuoneclipse.com%2F2012%2F02%2F13%2Fmake-my-make-with-eclipse-and-mcu10%2F%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%20%3CEM%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E5%AF%B9%E4%BA%8E%E4%BD%BF%E7%94%A8%E9%9B%86%E6%88%90%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%20Classic%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%8F%AA%E8%83%BD%E5%9C%A8%20Eclipse%20%E4%B8%8B%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%3E%E5%BD%93%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%8D%E6%98%AF%E7%8B%AC%E7%AB%8B%E7%89%88%E6%9C%AC%E6%97%B6%EF%BC%8C%E6%97%A0%E6%B3%95%E5%9C%A8%20Eclipse%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E5%A4%96%E9%83%A8%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%20style%3D%22%3A%20%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2012.0pt%3B%22%3E%E7%AC%AC%E4%B8%80%E9%98%B6%E6%AE%B5%EF%BC%9A%E5%9C%A8%20Eclipse%20%E4%B8%8B%E5%9F%BA%E4%BA%8E%20HC12%20%E9%A1%B9%E7%9B%AE%E5%88%9B%E5%BB%BA%E9%A1%B9%E7%9B%AE%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E1-%20%E5%9C%A8%20HC12%20v5.1%20%E4%B8%8B%E4%B8%BA%E6%82%A8%E9%9C%80%E8%A6%81%E7%9A%84%E8%AE%BE%E5%A4%87%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E2-%E5%90%AF%E5%8A%A8%20Eclipse%20%E5%B9%B6%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E7%A9%BA%E9%A1%B9%E7%9B%AE%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CEM%3E%E6%96%87%E4%BB%B6%C2%A6%E6%96%B0%E5%BB%BA%C2%A6%E5%85%B6%E4%BB%96%E2%80%A6%3C%2FEM%3E%3C%2FP%3E%3CP%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132666_132666.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132666_132666.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117861i50A26754E7575E54%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132666_132666.png%22%20alt%3D%22132666_132666.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111594i4394D89086F9E49F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN%22%20style%3D%22color%3A%20%23373737%3B%22%3E%E5%90%AF%E7%94%A8%3CEM%3E%E2%80%9C%E6%98%BE%E7%A4%BA%E6%89%80%E6%9C%89%E5%90%91%E5%AF%BC%E2%80%9D%3C%2FEM%3E%E5%B9%B6%E9%80%89%E6%8B%A9%3CEM%3EC%20%E9%A1%B9%E7%9B%AE%3C%2FEM%3E%EF%BC%88%E5%90%A6%E5%88%99%E6%98%AF%E9%9A%90%E8%97%8F%E7%9A%84%EF%BC%89%EF%BC%8C%E6%8C%89%3CEM%3E%E2%80%9C%E4%B8%8B%E4%B8%80%E6%AD%A5%E2%80%9D%3C%2FEM%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132667_132667.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132667_132667.png%22%20style%3D%22width%3A%20439px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117862i50817E600D4A9A86%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132667_132667.png%22%20alt%3D%22132667_132667.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20439px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111595i34565C9AEB28FFA0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN%22%20style%3D%22color%3A%20%23373737%3B%22%3E%E7%82%B9%E5%87%BB%E2%80%9C%E7%A1%AE%E5%AE%9A%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%8C%87%E5%AE%9A%E9%A1%B9%E7%9B%AE%E5%90%8D%E7%A7%B0%EF%BC%8C%E5%9C%A8%20Makefile%20%E9%A1%B9%E7%9B%AE%E4%B8%8B%E9%80%89%E6%8B%A9%E4%B8%80%E4%B8%AA%E7%A9%BA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%20%E2%80%94%20%E5%85%B6%E4%BB%96%E5%B7%A5%E5%85%B7%E9%93%BE%20%E2%80%94%20%E7%84%B6%E5%90%8E%E6%8C%89%E5%AE%8C%E6%88%90%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132668_132668.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132668_132668.png%22%20style%3D%22width%3A%20523px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117863i4C987399A4B6BF1E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132668_132668.png%22%20alt%3D%22132668_132668.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20523px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F23297i1AEFA0FC627D14D1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E7%A9%BA%E7%9A%84%E9%A1%B9%E7%9B%AE%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%3CEM%3EProject%C2%A6Properties%3C%2FEM%3E%E6%8C%87%E5%AE%9A%E6%88%91%E7%9A%84%E6%9E%84%E5%BB%BA%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%7Bsystem%3AECLIPSE_HOME%7D%2F..%2Fgnu%2Fbin%2Fmingw32-make%20-j6%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132669_132669.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132669_132669.png%22%20style%3D%22width%3A%20509px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117864i7FDC5CEA93E02722%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132669_132669.png%22%20alt%3D%22132669_132669.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20509px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1688i8033E818B3C7FE49%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2Csans-serif%3B%22%3E%3CBR%20clear%3D%22all%22%20%2F%3E%20%3C%2FSPAN%3E%26nbsp%3B%20%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E3-%E5%B0%86%E6%89%80%E6%9C%89%20HC12%20V5.1%20%E6%BA%90%E5%92%8C%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%20Eclipse%20%E9%A1%B9%E7%9B%AE%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E4-%20%E4%BD%BF%E7%94%A8%E8%8F%9C%E5%8D%95%3CEM%3EFile%C2%A6New%C2%A6Other...%C2%A6General%C2%A6File%3C%2FEM%3E%E5%88%9B%E5%BB%BA%20makefile%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%20style%3D%22%3A%20%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2012.0pt%3B%22%3E%E7%AC%AC%202%20%E9%98%B6%E6%AE%B5%EF%BC%9A%E4%BD%BF%E7%94%A8%20HC12%20%E6%9E%84%E5%BB%BA%E5%B7%A5%E5%85%B7%E9%93%BE%E5%92%8C%20makefile%20%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E1-%20%E7%94%9F%E6%88%90%20HC12%20v5.1%20%E7%94%A8%E4%BA%8E%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%22%3E%E9%80%9A%E8%BF%87%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%EF%BC%8C%E6%82%A8%E5%B0%86%E6%8B%A5%E6%9C%89%E7%BC%96%E8%AF%91%E5%99%A8%E5%92%8C%E9%93%BE%E6%8E%A5%E5%99%A8%E7%94%A8%E4%BA%8E%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%E7%9A%84%E9%80%89%E9%A1%B9%E5%92%8C%E5%85%B6%E4%BB%96%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%22%3E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E6%9D%A5%E5%88%9B%E5%BB%BA%20makefile%E3%80%82%3C%2FP%3E%3CP%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132670_132670.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132670_132670.png%22%20style%3D%22width%3A%20348px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117865iFDFC1BA7AD74A064%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132670_132670.png%22%20alt%3D%22132670_132670.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20348px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111596i0707275720B17792%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132671_132671.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132671_132671.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117866i45366ABDCE14FE90%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132671_132671.png%22%20alt%3D%22132671_132671.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111597iFB3BF6DFBAE147AB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E2-%20%E4%BD%BF%E7%94%A8%E8%8F%9C%E5%8D%95%E8%8F%9C%E5%8D%95%E6%96%87%E4%BB%B6%C2%A6%E6%96%B0%E5%BB%BA%C2%A6%E5%85%B6%E4%BB%96...%C2%A6%E5%B8%B8%E8%A7%84%C2%A6%E6%96%87%E4%BB%B6%E5%88%9B%E5%BB%BA%20makefile%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132672_132672.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132672_132672.png%22%20style%3D%22width%3A%20296px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117867iD8CBA296209946C2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132672_132672.png%22%20alt%3D%22132672_132672.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.png%22%20style%3D%22width%3A%20296px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111598iB43083D043A77A40%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_17.png%22%20alt%3D%22pastedImage_17.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132673_132673.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132673_132673.png%22%20style%3D%22width%3A%20248px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117868i9A4B59A33A4C39DE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132673_132673.png%22%20alt%3D%22132673_132673.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%20style%3D%22width%3A%20248px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111599i4D62294448D70663%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_18.png%22%20alt%3D%22pastedImage_18.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E7%A9%BA%E7%9A%84%20makefile%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E9%9C%80%E8%A6%81%E6%A0%B9%E6%8D%AE%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%88%9B%E5%BB%BA%E6%82%A8%E7%9A%84%20makefile%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%B2%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200.5in%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fmcuoneclipse.com%252F2012%252F02%252F13%252Fmake-my-make-with-eclipse-and-mcu10%252F%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fmcuoneclipse.com%2F2012%2F02%2F13%2Fmake-my-make-with-eclipse-and-mcu10%2F%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%BA%E8%AF%A5%E7%A4%BA%E4%BE%8B%E5%88%9B%E5%BB%BA%E7%9A%84%20makefile%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132674_132674.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132674_132674.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117869i3A0DAE2ACC685E02%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132674_132674.png%22%20alt%3D%22132674_132674.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111600iACCA441A4B353EE8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_19.png%22%20alt%3D%22pastedImage_19.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200.5in%3B%22%3E%E5%88%9B%E5%BB%BA%E7%9A%84makefile%E5%8C%85%E5%90%AB2%E4%B8%AA%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3CP%3Eall%20-%26gt%3B%20%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%E5%B9%B6%E7%94%9F%E6%88%90%20Srecord%20%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%E6%B8%85%E7%90%86%20-%26gt%3B%20%E5%88%A0%E9%99%A4%E6%89%80%E6%9C%89%E7%94%9F%E6%88%90%E7%9A%84%E6%96%87%E4%BB%B6%3C%2FP%3E%3CBR%20%2F%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E3-%E5%88%9B%E5%BB%BA%202%20%E4%B8%AA%20make%20%E7%9B%AE%E6%A0%87%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20text-indent%3A%200.25in%3B%22%3E%E4%BD%BF%E7%94%A8%E7%AA%97%E5%8F%A3%E4%B8%8B%E7%9A%84%E2%80%9CMake%20Target%E2%80%9D%E6%89%A7%E8%A1%8C%E6%89%80%E6%9C%89%E5%92%8C%E6%B8%85%E7%90%86%E6%93%8D%E4%BD%9C%C2%A6%E6%98%BE%E7%A4%BA%E8%A7%86%E5%9B%BE%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20text-indent%3A%200.25in%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132675_132675.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132675_132675.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117870iFCF2ABDDF6E9EBB9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132675_132675.png%22%20alt%3D%22132675_132675.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F23558iD0313F86B26311C7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_20.png%22%20alt%3D%22pastedImage_20.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.25in%3B%20text-indent%3A%200.25in%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132676_132676.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132676_132676.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117871i638689E1F1927FFB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132676_132676.png%22%20alt%3D%22132676_132676.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111601i8A2F572C4DBA72A7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_21.png%22%20alt%3D%22pastedImage_21.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20Eclipse%20%E9%A1%B9%E7%9B%AE%E4%B8%8B%E7%9A%84%20HC12%20v5.1%20%E5%B7%A5%E5%85%B7%EF%BC%88%E7%BC%96%E8%AF%91%E5%99%A8%2F%E9%93%BE%E6%8E%A5%E5%99%A8%EF%BC%89%E6%9E%84%E5%BB%BA%E9%A1%B9%E7%9B%AE%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2Csans-serif%3B%22%3E%3CBR%20clear%3D%22all%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CEM%20style%3D%22%3A%20%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2012.0pt%3B%22%3E%E9%98%B6%E6%AE%B5%203%EF%BC%9A%E6%B7%BB%E5%8A%A0%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%E6%9D%A5%E8%B0%83%E8%AF%95%20hc12%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EHC12%20V5.1%20%E4%BD%BF%E7%94%A8%E5%90%8D%E4%B8%BA%20Hiwave%20%E7%9A%84%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A5%E5%B7%A5%E5%85%B7%E4%BD%BF%E7%94%A8%E5%90%8D%E4%B8%BA%20.ini%20%E7%9A%84%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%81%E5%9C%A8%20Eclipse%20%E9%A1%B9%E7%9B%AE%E4%B8%8B%E4%BD%BF%E7%94%A8%20HiWave%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%B0%86%E5%85%B6%E5%AE%9A%E4%B9%89%E4%B8%BA%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E8%BF%90%E8%A1%8C%E8%8F%9C%E5%8D%95%E5%8D%95%E5%87%BB%3CEM%3E%E5%A4%96%E9%83%A8%E5%B7%A5%E5%85%B7%C2%A6%E5%A4%96%E9%83%A8%E5%B7%A5%E5%85%B7%E9%85%8D%E7%BD%AE...%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132677_132677.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132677_132677.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117872i958EB934C4018F63%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132677_132677.png%22%20alt%3D%22132677_132677.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_23.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_23.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111602iDAC2E8921092298D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_23.png%22%20alt%3D%22pastedImage_23.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%90%E8%A1%8C%E5%B0%86%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%8C%E5%B9%B6%E5%9C%A8%20%5CBin%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E7%94%9F%E6%88%90%20project.ini%20%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%BC%96%E8%BE%91%20ini%20%E6%96%87%E4%BB%B6%E5%B9%B6%E4%BD%BF%E7%94%A8%20.ini%20%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AFHC12%20V5.1%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2Csans-serif%3B%22%3E%3CBR%20clear%3D%22all%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%A6%81%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%AF%B7%E6%B7%BB%E5%8A%A0%E5%8F%82%E6%95%B0%EF%BC%9A%3C%2FP%3E%3CP%3Eproject.abs%20-w%20-Target%3Dicd12%20-Prod%3Dproject.ini%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132678_132678.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22132678_132678.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117873i97D2463AC59C442F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22132678_132678.png%22%20alt%3D%22132678_132678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%20style%3D%22width%3A%20624px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111603iBD7BE719124B7A9E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_24.png%22%20alt%3D%22pastedImage_24.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E8%B0%83%E8%AF%95%E5%99%A8%E5%B7%B2%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E9%80%9A%E8%BF%87%E5%A4%9A%E9%93%BE%E8%B7%AF%E6%8E%A5%E5%8F%A3%E5%8A%A0%E8%BD%BD%E5%88%B0%E6%9D%BF%E4%B8%8A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%BB%8F%E5%85%B8%20-%20%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%EF%BC%88%E5%A6%82%E4%BD%95%EF%BC%89%E5%9C%A8%20Eclipse%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20HCS12%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128943%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E6%95%99%E7%A8%8B%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E9%99%84%E4%BB%B6%E4%B8%8D%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B0%86%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Emakefile%20%E5%8F%91%E7%BB%99%E6%88%91%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎01-26-2016 07:41 AM
更新人:
