CW10 Memory Map "No CPU selected"
1,031 次查看
sskuce
I'm using a MC9S08GT16A, and Device Initialization works fine if I open the Project Panel and click the "Cpu:MC9S08GT16AFC" item first, but the Memory Map never fills in.  This component seems like it would be useful if it would only work right.
771 次查看
CrasyCat
Specialist III
Hello
As far as I can tell this view is available for projects created with processor expert only.
It is not available if you are enabling Device Initialization,
If you look at the Device Initialization reference manual ({Install}\MCU\Help|PDF\DeviceInitHelp.pdf) there is no mention  of Memory Map view in there.
CrasyCat
771 次查看
ProcessorExpert
Senior Contributor III
as "workaround" of missing memory map window in Debice initialization window could be considered usage of regular ProcessorExpert project and Initialization components. Generally it would not be much diffference and the requested window will be available.
best regards
Vojtech Filip
Processor Expert Support Team
