CW 6.1 Install on XP
nareec
I have tried to install CW 6.1 on XP and it almost finishes, but then says that it was interrupted and does a roll back. Does anyone know what is going on with this install?
CrasyCat
Specialist III
Hello
Before starting installation of CodeWarrior for MCU V6.1, make sure you disconnect all debug cable (USB, parallel, ...) from the host PC.
I assume you had some cable plugged in and the installation script was not able to install the drivers.
CrasyCat
