CW 6.1 Install on XP
2,243 次查看
nareec
I have tried to install CW 6.1 on XP and it almost finishes, but then says that it was interrupted and does a roll back. Does anyone know what is going on with this install?
1,094 次查看
CrasyCat
Specialist III
Hello
Before starting installation of CodeWarrior for MCU V6.1, make sure you disconnect all debug cable (USB, parallel, ...) from the host PC.
I assume you had some cable plugged in and the installation script was not able to install the drivers.
CrasyCat
