CW 10 autosave before compile
1,445件の閲覧回数
barbercolman
Is there an autosave before compile option?
2 返答(返信)
1,177件の閲覧回数
CrasyCat
Specialist III
Hello
Not sure which version of CodeWarrior you are using and which processor you are targeting.
Basically to instruct the IDE to save dirty files before building:
  - Select Windows > Preferences
  - In the Preferences dialog switch to the General > Workspace page
  - Set Save required dirty editors before building to Always.
  - Click OK to save the change.
This setting will remain valid for all projects inside of the workspace.
CrasyCat
1,177件の閲覧回数
barbercolman
I am new enough to CW I forgot to give processor and CW version, but your directions worked.
