C compiler doc
C compiler doc
1,786件の閲覧回数
michaelp
Where can I find a C compiler documentation, like register conventions, pragmas, intrinsict and so on? Is it a part of CodeWarrior documentation?
I'm using SC140 core DSP's like MSC8122.
I'm using CW v2.6, build 14
Michael
1,095件の閲覧回数
J2MEJediMaster
Specialist I
Take a look in the Help directory, which is a subdirectory of the CodeWarrior install directory. There should be a compiler and linker manual in there. If not you will have to run the installer again and have it install the documentation, and only the documentation.
---Tom
