Automation on CW10
Automation on CW10
1,965 次查看
RValls
Hi all!
I have recently downloaded CW10, and I am able to do the normal stuff, i.e. convert a project from CW7 to CW10, set targets and program them to the boards, etc...
Now I am trying to do the same I was doing on CW7 about automation.
I have got some programs that comunicates with CW7 through COM objects, but in the new version I can't register the servers by double clicking {InstallPath}\MCU\bin\Mwregsvr.exe.
It asks me for the dll, which on CW7 it autosearched.
Does CW10 have got support for automation? If so, please tell me where can I found some documentation (no .pdf contains anything about this topic).
Tbanks in advance,
Rubén
1,361 次查看
J2MEJediMaster
Specialist I
CW 10 does provide automation, but it is through the use of Tcl.
---Tom
1,361 次查看
RValls
Ok then. I have already investigated about TCL, and with it I can do all what I need. Just one last question: Any time I execute the IDE to execute a script (by using the command line cwide.exe -vmargsplus -Dcw.script=D:\my_script.tcl) it launches a new instance of the IDE. Is posible to execute the script on the instance that is already opened?
Thanks for the quick response,
Rubén
1,361 次查看
J2MEJediMaster
Specialist I
Within the IDE, open the Debugger Shell view. Then, execute your Tcl script from within it.
---Tom
