56F801 programmer tools
5,324件の閲覧回数
56F801programme
I'm a new user, I program for DSP 56F801, I use Codewarrior for DSP v7.0, I need the simply programmer tools, please help me.
タグ(1)
3 返答(返信)
2,499件の閲覧回数
J2MEJediMaster
Specialist I
You should have a suite of developer tools within CodeWarrior, such as the editor, compiler/linker, and debugger. Could you be more specific as to what you're looking for?
---Tom
2,499件の閲覧回数
56F801programme
I had *.s file I want download s file to dsp 56f801, I need some simply tool to do it, please help me
2,499件の閲覧回数
J2MEJediMaster
Specialist I
Go to the directory C:\Program Files\Metrowerks\CodeWarrior\Freescale_Documentation\pdf\800. In there you'll find a document, 8xx_Bootloader.pdf, which describes how to build a serial bootloader program. This program downloads S1 records to the target processor. The source for the bootloader is in a zip archive file located in the same directory, and you'd use CodeWarrior itself to build it. This should get you started.
---Tom
