16 bit in CW
16 bit in CW
3,702件の閲覧回数
ernestsnaith
How do you access only the high and low byte in CW?
Cheers
3 返答(返信)
1,568件の閲覧回数
CrasyCat
Specialist III
Hello
Which processor are you targeting (MPC, Coldfire, HC12, ...)?
What are you trying to do exactly?
Are you trying to access MSByte and LSByte from an address in assembler?
Are you trying to do that in ANSI C?
I need more information to provide an answer.
CrasyCat
1,568件の閲覧回数
rhinoceroshead
Try this:
int a16bitNumber = 0x1122;
char* ptr;
char lowByte, highByte;
ptr = (char*)&a16bitNumber;
highByte = *ptr++;
lowByte = *ptr;
Now highByte will hold 0x11 and lowByte will hold 0x22.
1,568件の閲覧回数
CrasyCat
Specialist III
Hello
I still need to know the processor you are targeting (HC08, HC12, Coldfire, EPPC5xx, .....)
CrasyCat
