zstar source code
zstar source code
andreato
Hallo,
I would like to compile the zstar source code  (ZSTAR.USB.mcp) because I will modify it for a new application.
I'm using the original source code but I obtain 121 errors by using codewarrior 6.1.
I suppose that someone (Freescale of course) has just compiled it and download the software in the target.
Can someone explain me how to do?
Thank you.
ok2ucx
sometimes earlier this year, the ZSTAR source tree has been updated on Freescale web in order to support the changed file tree of CW6.1. Download the latest version and it should compile fine (it is OK with my installation here). If not, let us know.
Pavel
