using FLASH as EEPROM
Billy
I am having some problems trying to convert the assembly language from the standard application notes provided by Freescale into C, for using flash memory as EEPROM . I am using MC68HC908QY4. I understood clearly the program flow. Can anyone provide me some reference of using a C language to do the job? appricaited.
UcTechnoGeek
Fresh Out Contributor
Search for app note AN2504.  It might help.
It explains the C APIs used in Codewarrior to do flash programming routines.
uCTechnoGeek
