usb icp programming with 68hc908jb8
2,390 次查看
five
I am working with 68hc908jb8.
Now i'd like to implement icp programming via USB.
I downloaded an2398, program the icp firmware but i am not able to let icpusb program work.
Anyone with experience??
Thank you
1,322 次查看
five
Thank you Peg,
i found about jB16, but JB16 has a preinstalled monitor code to connect via usb.
I have JB8 and i am a step behind. I have download an2398SW application note, i have programmed the firmware on the chip but i can't get the connection with the device. WinXP see the new hardware but icpexe program fails to connect (error in open_device()).
Usb routines must be programmed in user code before connecting??
Any help, thank you
Five
1,322 次查看
peg
Senior Contributor IV
Hello and welcome to the fora, five.
Take a look in the TBDML forum for some threads on this written by me (Use advanced search).
