reallocation of memory - MC9S08JM60
roop
hi,
I am using a microcontroller MC9S08JM60. When I burn a code in DEMOJM Board I found a memory allocated for  some Global variable and local variable of some function is same.
Can any one help me?
Please reply
Added p/n to subject.
Message Edited by NLFSJ on 2008-09-24 01:37 PM
CompilerGuru
Increase STACKSIZE in the prm.
Your description sounds as if you do use more stack space as the prm file assigns to the stack.
