pwm generation - MC68HC908jk3E
sathya
 hi to all
am sathya,
   can u just write a program to generate PWM waveform using
MC68HC908jk3E controller (using interrupt ) (am using codewarrior compiler)
dat is having varying pulse width
ok thanks to all,
Added p/n to subject.
Message Edited by NLFSJ on 2008-05-21 10:21 PM
J2MEJediMaster
Specialist I
Welcome to the forum. You might try searching the forums using the strings "PWM" and "pulse". That shows several threads on this topic. You can enter those strings into the search box at the bottom left of this web page.
---Tom
