problem to debuging MC68HC908AB32
wasimakram
HI
I m working on 8-bit MC 68HC908AB32, but during programming (debugger is MON-08 MULTILINK) I faced some problem
maximum time debugger show the message >>
CMD>CM
Loading programming algorithm routine... Done
Ereasing . Erasure of secure device done forcine power down to bypass security.
starting power down sequence.....
Trying security $FFFFFFFFFFFFFFFFFFF could not measure target baudrate
Acess Denied
                 (68HC08 Device responded properly ,But ROM is secure)
Error 48 During Script!
and some time it debugg ok with no above message
m little confused
wasimakram
Reply your opinion please
