problem UART
problem UART
pallav
I am using QB4/8
is it possible to use uART as :
ESCI enabled
transmitter disabled as used as i/o pin for output operation.
reciever enabled and used for recieving serial data from PC.
plz tell some procedure do so.
please help.
regards
Pallav
peg
Senior Contributor IV
Hi Pallav,
I would have thought this was possible.
1. What do you mean ESCI enabled?
2. Are you having some specific problem implementing this?
Regards David
