mem file for MMDS0508
add524
Where can I download the mem zip files for all the 05s and 08s?
J2MEJediMaster
Specialist I
Are you saying you want to download the example code for the HC08 and HC05 processor?
---Tom
add524
I solved the problem by finding the mem files for MMD0508 on an old hard drive.
I did a get reply with some/all(?) mem files from the service request. But it should be easily found an posted on the Freescale web site. There are many of us who will use "old/obsolete" equipment like the MMDS0508.
As Microsoft upgrade from this to Vista to whatever, I hope that Freescale keeps us in mind and does not force us to throw away our good, working and familar equipment.
rocco
Senior Contributor II
No, I'm sure he is referring to what Motorola called "mem config files".
You can get many of them here:
http://www.freescale.com/webapp/search/MainSERP.jsp?assetLocked=true&SelectedAsset=Design%20Tools
Having spent over $4000 on a MMDS0508 development system only a few years ago, I'm disappointed that Freescale won't support it. If you search for "MMDS" or "MMEVS" on the Freescale web site, you get 0 hits. Yet this is what Motorola touted as the 'must-have' for HC08 development, and is still sold through distributors.
OOPS!
only 10 minutes later, the above link no longer turns up the .mem files. I will have to refine the search again.
OK, it looks like the results of a search cannot be posted. No matter what I search for and what I find, the link is the same.
Try going to the above link, and type ".mem" in the "Refine your Search" box.
Message Edited by rocco on 2006-07-12 03:04 PM
add524
I solved the problem by finding an old hard drive and copying the files from there.
I agree with your comments about Freescale and the MMDS0508.
