help bootloader table vector application
yurifernandes
please can you help me I am trying to change this bootloader example, attached only I am not following configure the application table if I load the bootloader with the bootloader s19 itself but if I load the application s19 the vector table is wrong someone can take a look and help me where I am wrong please any help saw sawing thank you ...
