hardware for develope HC08
pele
Hi, everyone,
      My question is, if i want to learn to use HC08, what is the good budge for the hardware. Thanks!
pele
Thank you, peg.
Pele
HonHo
Hi Pele,
I suggest our low cost hardware starter kit, PK-HC08QY4 to you. The PK-HC08QY4 Starter Kit has been designed for the evaluation of the MC68HC908QY4 microcontroller and the debugging of small user applications. For more detailed information, please visit our website, www.softecmicro.com.
Thanks. :smileyhappy:
joerg
To continue the list
you may look at http://www.systech-gmbh.ch/indexHCS08System.html for the hardware and http://www.systech-gmbh.ch/indexEBS08.html for a simple OS for the CW 5.x
Saluti Joerg
eckhard
Contributor V
if you want to build it yourself, here is one more for the list.
http://www.eckhard-gosch.de/controller/controll.htm
Eckhard
Alban
Senior Contributor II
Hello guys,
:smileyvery-happy::smileyvery-happy::smileyvery-happy: I see that everyone is preaching for his own Church :smileyvery-happy::smileyvery-happy::smileyvery-happy:
(French expression of the day)
Fair enough you all have very good products indeed !
Pele, you can trust these guys.
Hon Ho, please read your private message. For that click on the enveloppe on top right. I would like your point of view on something.
Cheers,
Alban.
UcTechnoGeek
Fresh Out Contributor
Don't forget about Witztronics for the HCS08 BDM.
uCTechnoGeek
pele
Hi, all
  Thank you all  for your expertee and information. How about using MON08 multilink and codewarrior?
peg
Senior Contributor IV
Yeah, that will work too!
Buy a Multilink either direct from P&E or from this site and you can use it with either free software from thei site www.pemicro.com or CW from this site.
P_EMark
pele:
The HC08 has many low-cost development tools available. A good place to get started is with P&E's Free Simulator/Assembler (available for a select array of MCUs), or with Codewarriors starter edition (which also has a free version, along with P&E's Full Chip Simulation integrated into the software). P&E's software can be found here:
P&E's Free ICS Software
P&E also offers low-cost development tools for all Freescale MCU's. More information can be found on our homepage.
Mark
P&E
Message Edited by P&E Mark on 2007-02-1503:20 PM
