about how to use the BDC interface to program the on-chip FLASH issue.
2,754件の閲覧回数
PeterTsai
I'm studying about DIY burnner for SH8. I aslo studied about the chapter of development Support in satasheet. Now, I can launch some simple operation. for example, SYNC and READ_STATUS command and so on. But how to program a complete the content of S19 file to SH8? I launch WRITE_BYTE or WRITE_BYTE_WS command. but it seem don't be program to flash memories. Why? Please someone can give me some advices.
2 返答(返信)
1,898件の閲覧回数
eckhard
Contributor V
you can´t write directly into FLASH memory. You havo to load your code to program the FLASH into RAM and execute it from there.
Eckhard
1,898件の閲覧回数
PeterTsai
Hi Eckhard ,
In fact, I need to built a alone programmer without PC to burn source code in new target board. So I want launch some command and load source code to new mcu by BDM communication.  Is It practicable ? Please give me some advice again.
Peter Tsai
