ZigBee transmision power
2,157件の閲覧回数
jcuesta
HI all, and thanks in advance.
I have been cheking the range of the zigbee development board and im surprised it only reach 8 to 10 metters, would like to know if there is any way of increasing the transmision power of the antenna and in case there is, a document where i can read about how to do it.
Thanks again.
(Alban moved to pertinent board + renamed for clarity)
Message Edited by Alban on 2006-11-14 05:41 PM
1,091件の閲覧回数
Alban
Senior Contributor II
Well, your question being identical to ZigBee MC13193 general questions I would adivse you to use the search facility.
It would save you a lot of time as you would have had the answer straight away...
Please all use the Search function (bottom of page) to avoid asking again and again the same question...
Thank You !
Alban.
