Zero Insertion Force (ZIF) Socket a 42-pin device
byteybird2
I need a ZIF socket for the 42-pin (DIP) HC08AP32 device.  This part has a pitch of 80 mils.
Currrently the part is being programmed on the board thru a JTAG connection.  But I need to programmed as a standalong for replacements.
I found a manufacture about a year ago, but can't find the site again.
Does anyone have a source they could point me to.
peg
Senior Contributor IV
byteybird2
Yes, but the pin-to-pin spacing must be 80 mils.  The standard is usually 100 mils.
The package callout by freescale is:  SDIP-42.
I'll contact the company and verify.
byteybird2
Just verified the tech spec on the part and it is 70 mils.
This looks like what I need
   Thanks again
