What is the difference between S08CPUV2 and S08CPUV3
1,353 次查看
samgailbreath
1,262 次查看
vicentegomez
Hi Sam
There are some improvement on the design of S08CPUV3 vs S08CPUV2 but the performance is the same.
The main differences are on the modules you can check which module also change the revision and check the differences like the TPM
Vicente Gomez
