What does Error 14 mean? - MC13213
VincentLau
Hi, all
   What does error 14 mean when I trying to download code into my PCB for MC13213 though PE?  I measure the reset signal, there is a regular disturb peak signal in it. And there is no signal output on CLK0. Why it happen? Can anyone help me?
Best Regards
Vincent
July 15, 2008
Added p/n to subject.
Message Edited by NLFSJ on 2008-07-15 08:35 AM
Zahar
Hello Vincent,
A pulse on a RESET line means that your processor is always resetting.
Error 14 on the other hand means that there is a problem with loading the algorithm.
What is the name and the version number of P&E software that you are using? Please attach an algorithm that you are using to this message thread.
What is the name/revision of the hardware interface that you are using?
Are you using an evaluation board from Freescale, or is this a custom board of your own design?
Zahar
P&E
peg
Senior Contributor IV
Those pulses on reset are normal.
Refer to this thread.
