Using OOP/C++ in HCS08 devices
2,077件の閲覧回数
GonzaloVictorio
I have not found detailed information in the freescale website or internet so I'm asking here hoping someone does have the answer.
How far can I go with C++ in HC08 devices? (I'm using specifically the MC9S08DZ60, 60kB Flash, 4kB RAM) I mean, can I really do all the fancy things of OOP confident enough for sharing code used in higher-level platforms (ARM9s, Cortex, etc) with smaller devices like HC08s?
I found some very old posts in the internet that mentioned that there were limitations using C++, that it wasn't fully supported. If that's still the case, where can I see documentation that helps me understand the requirements/limitations/implications/etc?
Thanks a lot!
1,401件の閲覧回数
RickN
Hi Gonzalo,
    I suggest that you download the Evaluation version of CodeWarrior for MCU v6.1, and you can see what is included for C++ features.  I haven't used C++ in the HCS08 family, but there is support for C++ in the Professional Edition and you can try it for 30 days if you download and install the Evaluation version.
      Rick
