USBSPYDER08 development kit from Digikey
andyb
I'm trying to purchase a USBSPYDER08 development kit from Digikey, but don't see it on the website. I know I need to call in to get the discount, but I wanted to make sure it is available before I confuse some poor sales rep.
Should it be available from Digikey yet? If not, any idea when it will be?
Alba: renamed and moved.
Message Edited by Alban on 2007-02-01 09:31 PM
NLFSJ
To obtain the discount, you need to sign up for the Black Widow Design Challenge at the following website:
If you do not want to sign up for the design contest, you can order it through the distributors Digikey, Avnet or Future through the following website: http://www.freescale.com/webapp/search/MainSERP.jsp#706597 The cost is $29
I hope this helps.
Nina
